Dear Sir or Madam,
I would like to ask you the color temperature of your LED pannels (in Kelvin) as well as their intensity in Lumen.
Could you please answer my question?
Thanks in advance.
Best Regards,
G. Martinez.
Diese Frage von Geoffroy M. bezieht sich auf Ultraslim LED Panel weiß, 90 LEDs, 30 x 30cm, 18W und wurde durch den FAQ-Bot automatisch eingestellt.
Details for the LED panels
If you change to the german language you found under the short discription many datasheets. The first datasheet Betriebsanleitung und Datenblatt für Led Panels says on site 4, that the panel with 300x300mm is approx. 1350 lumens bright and the color-temp is 3700k for warm-white and 5600k for cold-white.
Achim
Achim
