Is it possible to fit narrrow beam angle lenses to the matrix board.We want to create a collimated light box with your matrix but the light of each LED needs to be focused in a narrow beam angle, preferably 5 degrees to provide maximum collimation of the light beams
Diese Frage von Mike A. bezieht sich auf LED Matrix mini, white, 9x14, 24V, 504 LEDs, 5000K und wurde durch den FAQ-Bot automatisch eingestellt.
LED Minimatrix lenses
Why not?
In our shop you find different lenses with a small viewing angle gte* 10°,
but no lenses with a super small viewing angle less than 10°.
Please search on another places.
Note:
in 1m distance the spot is approx. 8.7cm in diameter and have approx. 3331 lux (lumens per square meter).
The light of each led with a lens is very bright and potentially dangerous, similar to a laser.
Note 2:
every glass or equivalent material sucks light. Best of is around 92%.
for 1 led: 19.92 lumens on input --> glass --> approx. 18.3 lumens on output.
* gte = greater than or equal
Note:
Note 2:
