hello, are the 10x10mm platine sufficient as a heat sink on the nichia nvsl219ct?thank you
Diese Frage von dannil d. bezieht sich auf Nichia NVSL219CT 280lm warmwhite, with PCB (10x10mm) und wurde durch den FAQ-Bot automatisch eingestellt.
nichia nvsl219ct
The 10x10mm board brings the electrical connections of the Led from bottom to top and increases only the area, so that the operating heat of the Led can be better transferred to a heat sink. This board is not a heat sink.
