60cm SMD
FAQ-Forum-Bot
Di, 29.03.16, 05:25
Can I pls have the dimensions of the 60cm SMD high power profile.And pls what type of high-power LED modules (the ones with the most lm/w available that can be used on the 60cm said profiles
Diese Frage von James S. bezieht sich auf Aluminium profile 60cm for SMD High Power modules und wurde durch den FAQ-Bot automatisch eingestellt.
Di, 29.03.16, 06:36
Please read the description.
Quote: "Dimensions: 600 x 26 x 22 mm".
A drawing is available if you change the language to german.
Direct link (PDF, 1 page, 18.5kB).
Usable are all strips or modules with a max. power of 16.8 W.
