which power supply should I use?thanks
Cette question de NEPHOS se rapporte à Cree CXA3590 et a été suspendue automatiquement par FAQ-Bot.
POWER SUPPLY LED
For this led are no constant current sources in our shop available.
Links to Elpro (shop languages: german/english):
For all constant current sources are data sheets available. Read: PDF-article group
Meanwell LPC-150-1750
43 - 86V @ 1750mA, not adjustable or dimmable.
Meanwell LPC-150-1400
54 - 108V @ 1400mA, not adjustable or dimmable.
Meanwell HLG-120H-C1400A
54 - 108V @ 1400mA, adjustable through internal potentiometer (700 - 1400mA).
Meanwell HVGC-150-1050A
15 - 143V @ 1050mA, adjustable through internal potentiometer (630 - 1050mA).
Meanwell HVGC-100-700A
15 - 142V @ 700mA, adjustable through internal potentiometer (420 - 700mA).
Meanwell LCM-60DA
switchable constant current source, dimmable with DALI interface or push dimming.
2 - 90V @ 500mA
2 - 90V @ 600mA
2 - 86V @ 700mA
The output voltage ranges @ 900mA, 1050mA and 1400mA are not great enough.
Meanwell PCD-60-700B
50 - 86V @ 700mA, dimmable with phase cut dimmers (leading or trailing edge).
Meanwell LCM-60DA
2 - 90V @ 500mA
2 - 90V @ 600mA
2 - 86V @ 700mA
