Hello, I am thinking of purchasing this product. http://www.leds.de/en/High-Power-LEDs/C ... #012;which power supply would I need to run ten of them in parallel? Or should I run them in series? Any suggestions would be appreciated. Thanks!
Diese Frage von Dan bezieht sich auf Cree XB-D E8, warmwhite, 207 Lumen und wurde durch den FAQ-Bot automatisch eingestellt.
power supply
You should run then in series. For 10 you need a driver with about 25V to 35 V and 350mA or 700mA current (or something in between). This depends on the possible cooling. For 350 mA this driver would be sufficient: http://www.leds.de/LED-Zubehoer/Stromqu ... -IP20.html
For 500mA: http://www.leds.de/LED-Zubehoer/Stromqu ... 500-A.html
For 700mA: http://www.leds.de/LED-Zubehoer/Strom-u ... 700mA.html
