I would like to have a product like this but with a length greater than 1 meter, maintaining the separation between LEDs. Is it possible to concatenate units and maintain the density of leds?
Diese Frage von LuisM bezieht sich auf MaxLine 70 und wurde durch den FAQ-Bot automatisch eingestellt.
Extending the length
Yes. According to the product picture this should be possible. But you need to use separate wires for each unit. The power of the MaxLine 70 is to much to chain the stripes without additional wires.Is it possible to concatenate units and maintain the density of leds
The MaxLine is designed to allow a chain of up to 5 Modules.
So you can hook up the first Module to your power supply, connect + and - of the opposite side via wires to the next module and so on.
Please also Keep in mind, that the MaxLine modules have to be mounted on cooling elements to prevent the modules from overtemperature.
I'll add an Picture of an existing installation this afternoon.
