Info Item no.25001
FAQ-Forum-Bot
Di, 04.01.11, 11:50
Hello! can i connect the item 25001 to the constant supply Item no.95041?
Thanks
Diese Frage von Michele bezieht sich auf Chromed LED screw white, IP67, 12V und wurde durch den FAQ-Bot automatisch eingestellt.
T.Haid
Di, 04.01.11, 11:55
Hello,
no, you need a 12V power supply supply, this one for example: http://www.leds.de/LED-Zubehoer/Strom-u ... directed=1
Di, 04.01.11, 11:58
Helo, to explain : please read the name of the product, there you see that its driven with 12V. Item 95041 is a constant current supply, you need a power supply as Tobias told you here before.
