how to integrate the LED to my PC?Can you provide some suggestions?
Diese Frage von Li . bezieht sich auf Nichia SMD LED UV NCSU275, with PCB (10x10mm) und wurde durch den FAQ-Bot automatisch eingestellt.
connect to control system
An UV (ultraviolet) led is not a toy. Its light is very dangerous (Risk group 3 = Hazardous even for momentary exposure).
If you know the risk you can use a constant current source to drive the led.
Meanwell LDD-500LW
To power the constant current source use the 12V DC from your PC.
The led need cooling, heat sink requiered.
Meanwell LDD-500LW
