Dear Lumitronix Team I need to know if the folloowing product: Philips CorePro LEDspot 5.5-35W 827 GU5.3 MR16 36° (total 8 pieces), may be used with a traditional Toroidal Transformer 12v 300w , the same for halogen lamp, or I need a different electronic transformer for Led lamp ?Tks and regardsMauro
Diese Frage von Mauro bezieht sich auf Philips CorePro LEDspot 5.5-35W 827 GU5.3 MR16 36° und wurde durch den FAQ-Bot automatisch eingestellt.
transformer
Hello Mauro,
a toroidal transformer is nearly the best you can use for this kind of LED spots.
You can use the existing transformer for the LED spots - only the efficiency of the transformer itself will decrease a bit due to the lower load.
Greetings
K Mader
Greetings
K Mader
But only a few percent. For 8 Spots around 45W are needed. This is about 15% load. According to this graphic:
a 300VA toroidal transformer has still more than 90% efficiency.
(source: http://www.nuvotem.com/en/products/pdf/ ... Feb-08.pdf )
