dimmer for ultraslim panels
FAQ-Forum-Bot
Fr, 07.11.14, 22:12
Can i use one of siemens delta profile dimmer 5TC8904 to control ultra slim les paneles?
Diese Frage von Raul bezieht sich auf Ultraslim LED Panel Professional, 360 Nichia LEDs, 60 x 60cm und wurde durch den FAQ-Bot automatisch eingestellt.
Sa, 08.11.14, 08:38
Siemens Delta Switches and Socket Outlets
5TC8904 = plastic knob for a rotary dimmer.
The power supply needs one of following inputs:
Pulswidthmodulation (PWM),
0 to 10V control voltage,
DALI,
Infra red
If your dimmer has not one of these outputs, it is not compatible.
raulix
Mi, 14.01.15, 21:01
Thank you for clarification!
can i use then Dimmer for LED modules with turn control: http://www.leds.de/en/Accessories/RGB-D ... ntrol.html?
Thanks for your fast reply!
