info
FAQ-Forum-Bot
Fr, 16.05.14, 19:05
hi, these led module need heat dissipation?
Diese Frage von riccardo bezieht sich auf MaxLine 70 und wurde durch den FAQ-Bot automatisch eingestellt.
jguther
Sa, 17.05.14, 20:15
Yes.
If you run them at 700mA as recommended, the power consumption is 14W. 3W are converted to light, but the remaining 11W have to go somewhere. The surface area of 46cm*cm is not sufficient - you definitely need a heat sink.
Assuming an ambient temperature of 25°C and an LED temperature of 85°C, the heat sink should be rated at 5K/W or better.
