Dear Support team,
i'm very interesting to create 3 set of lamp with 18 pieces of 6W SmartArray per lamp. Every lamp will be mounted in 90 cm aluminum profile. Please let me which kind of power supply is required, how is possible to connect all the module together and if cooling is required. Please let me know also what is the weight of each module and the weight of the aluminum profile.
Diese Frage von Alessandro G. bezieht sich auf LED SmartArray, 12x Nichia LED, 6W und wurde durch den FAQ-Bot automatisch eingestellt.
Nichia SmartArray 6W
- R.Kränzler
For example you can use the contantcurrant supply 95058 (350 mA) or 95077 (700 mA).
Each one can drive four of the SmartArrays connected in series.
Your question of cooling ist not to be answered easily. We can give no general recommendation for a heat sink because the heat management depends on many factors, we can not know or estimate (eg ambient temperature, air flow, heat transfer).
Thanks for your answer.
The module will be used inside an exhibition where normally the temperature is around 25° C and around the lamp there isn't nothing, so the airflow is good.
My question is if is possible to use Item no.55120 like a cooler and if there's risk of damages for the led.
In alternatives please suggest me some other product that no requires cooling system and that are able to produce around 35000 lm below 6 mt of linear length.
Regards
Alessandro
Regards
Alessandro
