Hello,Do you deliver in Portugal?If you have a flat concrete ceiling is it possible to install the power supply inside the luminair
Diese Frage von Antonio A. bezieht sich auf Lumego SIRIUS LED Panel silver 120 x 30cm und wurde durch den FAQ-Bot automatisch eingestellt.
Sending to Portugal and ceiling applyance
Lumitronix deliever his goods to all countries inside Europe, Portugal too.
More information about shipping you found here: Shop - Infocenter - Shipment.
Inside the luminair there is no room to install a power supply. The panel ist only 14mm thick.
If you don't can make a hole inside the ceiling you must mount the power supply on another place (some meters away).
Or you must build a framework between panel and ceiling. Inside this framework you can mount the power supply.
The height of the framework must a little bit higher than the height of the power supply.
Or you use the suspension set to hang up the panel:
Lumego SIRIUS Panel suspension set.
Suitable power supplies (AC dimmable).
Link to our shop:
Meanwell PCD-40-700B (output panel: 3300 lumens = approx. 4 bulbs each 60W, height of this power supply: 31,5mm).
Meanwell PCD-60-1050B (output panel: 4900 lumens = approx. 6 bulbs each 60W, height of this power supply: 31,5mm).
Link to Elpro:
Meanwell PCD-40-500B (output panel: 2300 lumens = approx. 3 bulbs each 60W, height of this power supply: 31,5mm).
Note: all prices @ Elpro are without Vat and without shipping costs.
Link to our shop:
Link to Elpro:
