Power supply for Nicha NSBWL121A
FAQ-Forum-Bot
So, 15.03.15, 15:10
Hello. Is Meanwell PLM Serie 40W PLM-40-1050 (1050mA) OK for 1pc Nicha NSBWL121A ?
Diese Frage von MarkoB bezieht sich auf Nichia Chip on Board NSBWL121A 2110lm white und wurde durch den FAQ-Bot automatisch eingestellt.
K Mader
Di, 17.03.15, 08:18
Hello Marko,
the LED requires a voltage of about 36V (changing over temperature) when driven with a constant current of 1050mA.
The PLM-40-1050 has got an Output voltage range of 29 ... 57V.
This means the voltage Range is well above and well below the required voltage and the constant current source should work nicely with the LED.
Please keep in mind that this LED (like every other high power LED) has to be cooled!
Best regards
K Mader
