Hi, we want to make a desing using the smd-led module.
How many led modules can be used with the same controller. How many watts has each module. And they come soldered or we have to solder each one?
Contact by email,
Thanks
Diese Frage von Raimon P. bezieht sich auf LED module blue 3 x SMD-LED, 49mm 12V und wurde durch den FAQ-Bot automatisch eingestellt.
Led module
What's the max. power of this controller?How many led modules can be used with the same controller
Each modul has 0,2 watts @ 12V DC.
Max. power of the controller minus 10%, better 20% (or a little bit more for reserve) divide through the power of 1 module = max. value of modules.
For example:
controller: 12 watts
12 watts - 20 % = 9,6 watts
9,6 watts / 0,2 watts = 48 modules.
End of example.
If you buy some modules (more than 1), you get a strip.And they come soldered or we have to solder each one?
