I need a resistor with a costant current adapter ?
Beitrag am Mi, 09.06.10, 12:34 (0 Bewertungen, 5 Sterne)
Hi, I'm Bruno from Torino-Italy, I'm buying 9 Cree XR-E 7090 royal blue and i want to power them in a serial connection with your costant current supply 700 ma IP20. The XR-E 7090 at 700ma need 3,5V, My question is : I need a resistor to connect ((9*3,5)+1) the 9 leds to the IP20 ?
DESCRIPTION_REQUEST_FORUM_FOOTER
FAQ-Forum-Bot
Sterne: 66
Re: I need a resistor with a costant current adapter ?
Beitrag am Mi, 09.06.10, 12:40 (0 Bewertungen, 5 Sterne)
Hello Bruno,
that is not possible. The constant current supply is only for a maximum of 8 leds. Nine leds will not work. Just read the technical informations for the constant current supply.
I would prefer this constant current supply, but you need two of them: one time for 4 leds one time for 5 leds for example:
http://www.leds.de/LED-Zubehoer/Strom-u ... m=art%204e
You don´t need any additional resistor. All will work direct with the constant current supply.
schlosshund
Sterne: 231
Beitrag am Mi, 09.06.10, 17:29 (0 Bewertungen, 5 Sterne)
I assume you would like to use this constant current supply: http://www.leds.de/LED-Zubehoer/Strom-u ... -IP20.html
In this case the previously made statement is incorrect! If putting all LEDs in a row the voltage you need is added up, the constant current supply can give at most 36V, if i divide these by 9 i get 4V which the LED might have max. to still be working at 700mA. Since these LEDs will very likely have a voltage of less than 4V at a current of 700mA the power supply should easily be able to supply 9 LEDs of this kind. What is correct is: You must not use a resistor! :)
Ronald90
Sterne: 211
Zurück zu Produktfragen
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 1 Gast
