PCB for Emmiter NVSU233A
FAQ-Forum-Bot
Mo, 11.05.15, 21:42
I have an NVSU233A emmiter of Nichia and would like put it on PCB board. What is the best PCB boar for it? Do you have it?
Diese Frage von irwing . bezieht sich auf Nichia SMD LED UV NVSU233A und wurde durch den FAQ-Bot automatisch eingestellt.
Di, 12.05.15, 05:08
The NVSU223A has a similar footprint as the Nichia 119.
I think you can use it: Item no: 60038 - 10mm mini Alu Circuitboard for Nichia padsize 36 & 119 --> Note: that picture on product site is only for demonstration.
A data sheet for Nichia NVSU223A you found, if you change the language into german (technical problems with other languages).
