Dear sir/madame,Which heatsink do you recommend for this Nichia Chip on Board Modul NSCWJ216A 3550lm white?Kind regardsYves Walravens, Belgium
Diese Frage von Yves W. bezieht sich auf Nichia Chip on Board Modul NSCWJ216A 3550lm white und wurde durch den FAQ-Bot automatisch eingestellt.
Which heatsink
Hello,
the matching heat sink depends on the current of the LED.
Also no one can give you a recommendation of a heat sink, as long as (s)he doesn't know, how it should be mounted and so on.
There is no HeatSink in the Shop that can cool the LED at a current that's higher than 350mA.
The Star Cooler (Item no. 60024) should do the Job, if the LED is only driven at 350mA, when it is not covered by a case or something else.
A cooling Element can be calculated by: (Maximum temperature rise) / (LED current * LED forward voltage) = (Maximal thermal resistance of the heatsink)
The lower the thermal resistance, the better the cooling element.
The calculation isn't 100% exact but it gives a good ballpark figure.
Please keep in mind, that the thermal resistance is given at a uniformly heat source and free air convection, so better use a better heat sink than calculated.
Measuring the temperature of the module after installation for at least 1 hour would be the best way to find out, if the cooling is enough.
(The temperature of the LED shouldn't exceed 85°C.)
I hope that helps.
Regards
K Mader
I hope that helps.
Regards
K Mader
