Aluminium profile
FAQ-Forum-Bot
Di, 22.04.14, 07:34
Hi,Is it possible to mount the led strip: 53327 in one of Your aluminium profiles? ex. 55120?
Diese Frage von Kasper K. bezieht sich auf Aluminium Profile Set 1020mm, deep und wurde durch den FAQ-Bot automatisch eingestellt.
K Mader
Di, 22.04.14, 07:55
the width of the MaxLines is 16.5 mm.
The Aluminium case set, 600mm (Item no. 53810) would be the only profile that is wide enough for the MaxLine.
BUT when you want to put two MaxLines into one of those profiles, please mount the profile onto another cooling-element, otherwise the profile (and the MaxLine) will get extremely hot.
Regards
K Mader
