Is this product compatibile with Item 60495? (Description is quite confusing).Thank you.
Diese Frage von Dario C. bezieht sich auf LUXEON Rebel ES LXML PWN2, neutralwhite, 230lm und wurde durch den FAQ-Bot automatisch eingestellt.
Compatibility
You can buy the led in 2 variants:
1. emitter.
2. mounted on a Star. --> It's a Lumitronix Star.
The description of the BJB Connection module says, it is only compatible with manufacturers PCBs, not suited for Lumitronix Star PCBs.
They are not compatible.
1. emitter.
