Hi
The technical information is not correct on the page. The Philips MasterLed 4w GU10 warm white I ordered has better specifications than what is stated on the product page.
The Philips GU10 4W MasterLed I got has the following printed on the box.
40.000h
235 Lumen
So the new LED's I got has actually better specifications
If I order some more, can I then be sure they are of the same type?
best regards
Heino
Diese Frage von Heino H. bezieht sich auf Philips Master LED Spot GU10 4W, warmwhite und wurde durch den FAQ-Bot automatisch eingestellt.
Philips 4w Masterled GU10 technical information is not correct.
Hello.
You can order some more, we only have the new version right here in stock with item 70604, the old one with 71689.
