Good morning,
I have to feed this product to a 12v battery, how can I do?
thanks
Diese Frage von Giovanni C. bezieht sich auf PowerBar LED Leiste warmweiß, 12 Nichia LEDs, 1814lm, CRI90+ und wurde durch den FAQ-Bot automatisch eingestellt.
Power LED bar
Hello Giovanni.
This won´t work any way. One PowerBar needs a minimum of 36V.
Modoeventi
so if you use the variant to 700 mA can attack more than three LEDs?
No. The number of LEDs you can drive with one Current Source depends on the Input Voltage. At 350 mA each LED has a Forward Voltage of typically 3 V. Three LEDs in a row will add to a voltage of 9 V. The Current Souce has a Voltage Drop of 2.5 to 3 V. Thus it should be possible to drive three LEDs with a battery supply of 12 V.
At 700 mA the voltage drop of each LED is typically 3.3 V, amounting to a total of 9.9 V. Add 3 V drop of the current souce and you're at 12.9 V. This is why a 700 mA Current Source will not work.
