maximum pcb width
FAQ-Forum-Bot
Fr, 09.07.10, 08:00
What's the maximum pcb width for this enclosure? Have you a drawing (dxf, dwg, iges,...)?
Regards
DESCRIPTION_REQUEST_FORUM_FOOTER
schlosshund
Fr, 09.07.10, 08:44
For which pcb do you want the data? You´re talking about an enclosure, so i think this items:
1. http://www.leds.de/en/LED-strips-module ... trips.html
2. http://www.leds.de/LED-Leisten-Module/H ... aram=53810
steph-62
Fr, 09.07.10, 08:55
For both if possible.
Ronald90
Mi, 21.07.10, 10:46
For the first it is 10mm for rigid PCB which you can slide inside. 8mm for rigid or flex which you want to put completly inside.
For the second its 19mm for rigid PCB which you can slide inside. 16,5mm if you cant slide it inside.
You can find these data from the drawings :)
