Hi, for a display closet i plan to use a multibar to lighten the inside up. I plan to put 1 strep on the right side, and 1 on the left side. I do not know however if i would need the multibar 35 or 49. The dimensions of the closet are: width: 50cm, depth: 32 cm. Would the 35 version be too weak if i put a strip both on the left and right side? The 49 too strong? Thanks for your thoughts on this.
Diese Frage von Matt bezieht sich auf MultiBar35 LED Strip 50cm 24V und wurde durch den FAQ-Bot automatisch eingestellt.
Multibar35 or 49
We dont know, how many light do you need.
The output of 2 strips Multibar35 (white) is 2x 310 lumens = 620 lumens. This is equivalent to a bulb with 50 watts.
The output of 2 strips Multibar49 (white) is 2x 780 lumens = 1560 lumens. This is equivalent to a bulb with 100 watts.
I mean, 2 strips Multibar35 is more than enough for that little box.
